oh whats up man i pm you on Titantalk....and i need to make a couple calls for the LCA'sI'm interested if you'll ship these for me. Also looking for the lower control arms if you have those as well. Let me know! Thanks.
yes they fit frontiers from 2005 and up only. and yes they are bigger for less coil bucket contact. thats what they use them for a mid travel kit instead of buying a kit since its cheaper to do and same results.Would these allow for less coil bucket contact with a lift then the stock, frontier ones? If so, I'll take them right now. I'll pay for shipping too! Or do these not even fit on the frontier? It's a 2009 btw
You need to research what is actually needed for the Titan swap and what the truck looks like afterwards. You CAN NOT just add the uppers without lowers and adding lowers pushes out the assembly 3" per side and on top of all of that, if you are 4wd, you require custom half shafts in you keep the r180 diff. If you need more info, then search and search and search, it is all out there and I am sure if you take the time, you will find what you need.Would these allow for less coil bucket contact with a lift then the stock, frontier ones? If so, I'll take them right now. I'll pay for shipping too! Or do these not even fit on the frontier? It's a 2009 btw
well these will work, and im pretty sure if you keep looking for the rest of the parts needed for the hole swap you wont end up paying over $350 if you find the right ppl for a mid travel kit by using the Titan parts, wish i could do that my self but there aint no other bigger Nissan truck to take em off for my Titan.......lolI'm just looks for a cheaper way to get less coil bucket contact in my future lift because I can't see spending $600 just for UCA. Thanks for the info though!
