Does that come with software? If so there's no information on what OS it runs on. Actually zero information on it at all.
You must be looking at the mobile page. The PC page has all the info.
But yes, comes with software. And like SMJ said, WinXP is the listed OS so I expect it will work in Win10.
Keep in mind that this is a knock off so I'm not surprised that some items won't work. But what does work could prove to be useful.
In any case, $24 is pretty low risk so I went ahead and ordered one. We'll see.
Here's the info:
"Nissan Consult Diagnostic Interface is a diagnostic and test tool for Nissan cars.Nissan Consult cable supplies Power from car battery over 14pin Consult Port of Nissan vehicles. It can check and clear the fault codes and adjust the timing and so on. Easy and low price tool for Nissan cars.
Highlights:
1. Language: English
2. Support System: Windows XP
3. Can't update
Nissan Consult Description:
1.Interface fitting for 14pin Consult Port of Nissan vehicles.
2.Heavy & robust casing for rough service use
3.Connects to PC via RS232
4.Powered from car battery over 14pin Consult Port of Nissan vehicles.
5.LED to control power and clock function
Nissan Consult Function:
1.Monitor and Log dozens of realtime parameters
2.Check and clear engine fault codes before going to an expensive auto shop
3.Adjust the timing and idle
4.Power balance testing
5.Reset the self-learn codes
6.Control idle air valves, relays (AC, fans, etc), timing
7.Diagnose customer vehicles on-site
8.Speed up troubleshooting of electronically monitored components
9.No software is supplied with this device
Nissan Consult Specification:
1.Software Include
(Note that some of them are not free and need to be purchased)
DDLreader: DDLreader v.15c / DDLreader v.16c
ConZult
ScanTechNissan
Z-Control
SRTalk v.1.0
ZCSetup v.2.0
ZTalk v.1.1
Nissan Data Scan v.1.4
Nissan Data Scan v.1.51
2.Workable Model
It works on all Nissan cars that have the grey 14pin Consult connector (you'll usually find it near the fusebox) (This cars are usually build from year 1989 to 2000) . Models such as: 300ZX, Z32, Maxima, 240SX, S13, S14, Skyline, SR20DE, SR20DET, RB20, Altima, Fairlady.
Nissan Consult Package List:
1pc x Nissan Consult interface
1pc x RS232 Cable
1pc x CD Drive
