1 - 8 of 8 Posts
going from 2wd to 4wd you will need a new yoke flange
2wd is 6 bolt
4wd is 4 bolt
bucksnort , the frontier is spring over your axle is spring under so you would need to relocate the springs perches but your driveshaft flange should bolt right up
Idle are you including the abs sensors with the axle as well as the harness's that plugs into the diff for the locker
2wd is 6 bolt
4wd is 4 bolt
Easier than regearing to match my crappy 180 up front.
1 - 8 of 8 Posts
