I've had the nismo CAI on for a couple years now and the filter looks really bad. I have recharged it several times and it has now lost most of its shape. Wondering how it has held up for other folks.
Also has anyone replaced the cone filter yet? If so where did you find one and what did you use?
I've been looking for a conical filter with a 3.25" flange and similar dimensions. The closest I have found is this one from K&N.
Part RU-5122 Product Specifications
Product Style: Round Tapered Universal Air Filter
Base Outside Diameter: 5.5 in (140 mm)
Flange Inside Diameter: 3.25 in (83 mm)
Flange Length: 1.625 in (41 mm)
Flange Type: Centered
Height: 8 in (203 mm)
Top Outside Diameter: 4.688 in (119 mm)
Top Style: Rubber
Top Material/Finish: None
Filter Material: Cotton Gauze
Filter Re-Oiling Amount: 1.6 oz (47 ml)
Weight: 1.2 lb (0.5 kg)
Product Box Length: 6.38 in (162 mm)
Product Box Width: 6.38 in (162 mm)
Product Box Height: 11 in (279 mm)
I may give this a try, but would be interested to see what others have found and or tried.
Top Style: Rubber
