Did the Nismo 2wd Crew Cab ever come with a manual tranny? I was all set to go buy a 2wd Pro-4x but to my dismay you can't get it in manual. I just don't understand...
I am now stuck a 4wd in manual or a 2wd in automatic. I really want a manual and I really want to build a prerunner..
Thanks,
Jeremy
no CC nismos came from nissan with a manual
buy why start with a nismo or pro 4 x if your going to build a pre runner a SE 6 speed is a better starting point IMO for a full on pre runner build
Thanks for the info...
I guess I should clarify a little in that it will not be a full on prerunner but a daily driver that I will go romping around dirt roads and some farms. I thought some of the luxury features of the pro4x interior would be nice.
I have thought about the SE though as then can get a moonroof without the goofy roofrack as well.
I am from the northreast so not a lot of desert running out here...
I agree with IronGrave. An SE CC 6m is your best bet. You won't have an e-locker but you will still have the m226 which allows you to install a TruTrac or an ARB air locker.
Think of it this way, if you are going to be upgrading the suspension, then what on the Nismo/Pro will be kept? Is it worth the extra cost? Yes the interior is special but if you really want it, you can probably get KatSkin or another company to make it for you. Then you can spend what you saved on the parts that you really want.
