i was wondering if there is a cheap lift that will raise the back and the front of my 05 king cab but make the front a few inches higher. is there a kit? i want the prerunner look
pre runner look as in wider or the "cali lean" with a front lift and the back stock.
wider OEM titan control arms and coil over slight lift and a wider
the IMO ugly cali lean look a spacer is a spacer get a cheep one
Guest
A lot of people use spacers and complain of a clanging when the suspension flexes. I put the AC springs on mine and broke my front shocks so there's several ways you can go. AC now has some softer springs that will prolly not brake your stock shocks but still lift you 2" I would recommend lift the front 2 and leave the back, and see what you think, you can always put add a leafs later if you want.BTW I have had 305/70 r 16's on mine before with only slight rub with my 2" lift.
:hi:
