2011 Pro-4x
Mods: SPC adjustable UCAs, Bilstein 5100 and 5125, Energy Suspension urethane bump stops and sway bar bushings, PRG heim joint end links, PRG poly engine and trans mounts, 3" lift spacer, 1" lift blocks, DIY 1" body lift, AEM drop in oil-less filter, IMS, Enkei RPT-1 18x9, BORA stud pattern adapters, DIY retro fit projectors and color temp matched(5k) led foglights, Stillen roll pan
