Finally got around to installing my auxiliary lights, been puttin' this one off for a while.
Used PIAA 510 ATPs, and a factory "off road lamps" switch from the newer Xterra. I ordered the switch last year and used a meter to find all of the pins, there's six total, 2 for the illumination LED, 2 for the "ON" indicator LED, and two for the actual switch.
Unfortunately, Nissan threw a curve ball on this switch, and it's only a momentary switch so I wired up some relays to latch on/off from a momentary pulse.
I also added some mesh grille to help cover them in the day, it's not much but it doesn't look too bad in the day, I'll try and post up some day time pictures as well as the pin-out for the switch and a diagram on making the latched relays for anyone interested in using this same switch.
shot of the mesh...
close up of the mounting brackets I used...
fully functional illumination on the light switch with the rest of the switches...
fully functional "ON" indicator...
would have been nice to have a harness, but meh
and of course, it still needs to be removed, so I added a harness
shot of the mesh...
