My '09 with 15k miles has recently started making a constant, not-very-loud, high pitched squealing noise. I've searched the forums and have found several threads about the belt tensioners in these trucks. However, none of those threads mentioned anything about the sound happening only when the truck is in gear (it's a 6 speed).
The noise:
1) Happens when the truck is in ANY gear. If I press the clutch pedal to change gears, the noise goes away. It comes back (and stays) when I release the clutch. If I have the tranny in neutral, the noise goes away regardless of the position of the clutch pedal.
2) The noise only happens when the engine is cold. After driving for about 10-15 minutes, the noise stops.
3) Once the truck is going over about 20 mph, vehicle speed and engine RPMs are completely irrelevant. The noise is constant and doesn't change with vehicle speed or engine speed. (If I drive very slowly in first gear, I don't hear the noise. I don't hear it in reverse either.)
4) The noise happens for just a split second right when I start the vehicle up.
Any ideas as to what might be causing this? Obviously, I plan on calling the dealership on Monday morning. But I'd like to see if I can get some information in the meantime.
The noise:
