I have had them on my '05 for like two years now. The halos went out on one side soon after and they are starting to look bad with some of the inside housing that is peeling away. If I had to do it over I'm not sure I would have bought them. And I was stupid enough to sell my OEM's. Live and learn I guess.
there is nothing else. leave 'em alone, or open them up and paint them like others have done. looks great.
spend $90 on some PIAA bulbs and you will have some bright headlights.
I used the LL (long life) bulbs from Sylvania. I put a set of them on my '94 sometime in the late '90's and they are still working to this day. Nothing like changing a bulb and forgetting about it for a decade or so.
I recently got my PIAA xTreme White Plus bulbs for $68 shipped through Amazon. It makes the lights a little brighter, but not much. It certainly doesn't come close to HIDs. The main improvement is with the color of the light. They are now much whiter than they were stock. I had hoped for more light gain, but will live with the fact that I at least have a 2nd set of bulbs (the stock ones) for whenever these burn out.
A second option is the Silverstar Ultra Whites. I think you can get them at your startard parts store (AutoZone, Advance Auto Parts, NAPA, etc) for around $45-50.
The key to our bulbs is that they are model 9007 (for the 2nd gens, not sure about the 1st gens). This is the dual filament bulb for both the high and low beams.
with all the money people spend on halogen bulbs trying to get close to color and output of an hid kit, why not just spend the ~$50-60 on an hid kit instead of spending more experimenting?
iv got the black halo headlights like roastbeef and iv had them for a while now and the halos are still goin nice. the only problem iv had is that it took me almost a week of tweaking them to get them aimed right. the lows kinda suck and have a shadow in them..but the brights are really good. and theres also a sticker on the light that says "no HID bulbs"...does anyone kno what thats about?
Everyone i know that's bought a set of ebay projectors has had problems with them getting water in them then not working shortly after. I would steer clear.
There really isn't much else out there as far as aftermarket headlights go. there was a company selling black OEM style headlights but i don't think you can get them any more. you may be able to find a used set on ebay or something. i THINK that's it.
Other than that you've got two options; read the tutorial that's stuck to the the top of this forum and black them out yourself or just keep 'em stock.
edit:
looks like ive got a twin now. Haha, nice truck yellow01.
i went on a ride down a powerline a while ago and my lights got some condensation or foggin up or whatevr in them...but they completely dried out and went back to clear in like a week..
guess i got lucky
Hello, I posted this in the new member forum but wasn't sure if it would be seen by many there so I am posting here.
My current 2004 Frontier SE is a 4cyl 5-speed manual with 285,000 miles. I have put a lot of new parts into my 2004 because I want to keep it running as long as possible. I...
I replaced plugs, wire, distributor cap and rotor, fuel regulator, iac solenoid, throttle, maf and egr valve. Some of these parts were probably not needed. I had a code p302 that will not go away. After replacing the EGR valve and solenoid, I have steady rpm now. New tires, tie rods and wheel...
Due to my tendency to rapidly accumulate too much miscellaneous crap in my center console, I am considering a column shift to floor shift conversion.
Now whether it would eliminate my "miscellaneous crap accumulation" or just relocate it is unknown.
Has anyone ever done this conversion or know...
hello everyone,
I think i have a missing vacuum line....can someone please take a look at my picture and tell me if a vacuum hose is missing..i circled it with a red circle...
…ing the pan?
I was sorting out a surging issue, cold idle/thermal switch adjustment, then TPS, then timing) and was following the troubleshooting diagram in the FSM.
I read some posts, googled and such, and came to the thought that since the TCM wasn’t giving me any codes, I might have a...
