Ok guys, I just got my 2000 Nissan Frontier Crew Cab. She is very clean, and only has 92,000 miles. I do have a couple of questions though:
1) One or more of the belts is squealing. I have reciepts from the original owner that the front belt and tensioner were recently replaced, so hopefully a quick tighten of the tensioners and alt will remedy that. Found a couple of good diagrams on the Xterra forum, as the Haynes Manual leaves a lot to be desired. Any helpful hints?
2) The truck has a small leak at the oil sending unit. Cheap part, but what do you reccomend putting on the threads to keep the new one from leaking?
3) There is a squeak coming from the passenger rear of the truck bed. You can jump on the passenger side rear bumper and make the sound. Are there certain suspension bushings I should be looking at?
Thanks guys, I hope to be here for a long time coming.
:hi:
:hi:
