1 - 3 of 3 Posts
Discussion Starter · #2 ·
Well can't yet post in the tech area, but here's my issue, no crank no start, will run if push/pull started but when cycling ignition all I get is a click/pop from the ignition relay and nothing else. Terminals are all clean and tight, clutch safety switch has been eliminated and hardwired, and the light test the lights do not dim when I try to start, thinking either starter solenoid or ignition relay? Any thoughts?
1 - 3 of 3 Posts
