1 - 4 of 4 Posts
Hey guys - did a quick search and didn't see anything related to my problem..
Had a bad fan clutch that I replaced yesterday - install went well, but now the A/C doesn't work at all - doesn't even kick on. Blower works - just regular fan air.
Truck is an '05 4L king cab.
Gotta be something simple - Anyone else run into this?
Discussion Starter #3
I double checked what I unplugged (which was only the breather hose, radiator hoses and MAF sensor connector to remove top of airbox) but I suppose it could've came loose when I moved the radiator shroud. I'll give that a glance over .. thanks.
What were your symptoms with the fan clutch? My is making intermittent noise and I'm leaning toward having to replace the fan clutch. I would like some input from people who have had similar problems.
While running my fan, it intermittently makes a strange buzzing sound, if I adjust the fan speed, it runs normal. Sound like a fan clutch? How big of a job is it to change?
1 - 4 of 4 Posts
