so i did as directed refraining from any wise cracks as directed and unfortunately came with no results. my window will not go down. I guess I will have to replace the motor... and I havent the slightest idea on how to do any of that...
My rear window on my driver side wont work from my control at the drivers side, but works perfectly at the door itself. i tried said advice but unfortunately- no results.. i dont get it.. lol
Hmmm.. the driver window won't go down, right? The left rear window won't operate from the driver window control, but it works fine from the left rear door control, right? What do they bot have in common? The driver window switch unit and the wires that run between them!
Try disconnecting the driver switch unit and applying 12 volts to the different pins on the plug that connects to the driver window control unit (use a jumper from the hot power outlet and make sure the key is in the full ON position) and see if the driver window or the left rear window operates. If they do operate, then you know it's not the motor or wiring but the switch assembly.
If you have been wheeling and bouncing and slamming the truck there's a good chance that you have loosened the connections.
Good luck, maybe someone else could chime in.
