1 - 9 of 9 Posts
Aloha... just ordered 18x8.5 rims with 5.25 back +12mm offset and i need tires. Currently have 2.5 all day fab spacers in the front and cold arch lift in the back. Im looking for tires in the 32.5 - 33" range AT. Do you think that 285/65/18 will fit? Still running the stock rims and tires which are toast. Currently have 43000 on my truck and they are as bald as professor X. LOL.. But really I need help. thanks
I dont have the rims yet, they are still on order. here is the website that carries the wheels.
Raceline Wheels - 896-Renegade 6 Chrome
Jeff024 - Did your run those tires with a 2.5in lift in the front?
Help!!! I really need new tires ASAP!! I am currently in training until 1May10 but as soon as i get home the rims should be there and i want to put the tires on the same day. Thank you again for looking/helping.
Those tires are a 32.6" OD, which is an inch taller than the stock Nismo meats. You should be ok with that lift I'd imagine, but as jeff024 mentioned, you'll have to do some trimming. Guessing that offset will stick them out a ways....mine are like a plus 30mm and are flush with the fenders.
thanks troyroyce!!!
pretty much all i wanna find out is what is the biggest tire that i can use with these rims with a 2.5 lift... Im guessing im going to be paying about $225 a pop for tires so i just wanna make sure i get the right one the first time.
anymore info would be great. thanks in advance. aloha
I ran them with the 4x4parts.com coils then Radflos
alright im going to go with the 285/65/18 bfg's or terra grapplers... i cant get a for sure answer on what is the biggest that will fit.. i would rather be safe then sorry.... thanks to everyone that helped.. if there is anyone else out there that thinks/tried to fit bigger tires on these rims please let me know. mahaloz again and aloha
Alright guys... Finally made up my mind on which tire i want to get but just found out a new size. BFG A/T KO 275/70/18... is this better or worse? i would rather have a taller tire then a wider tire. Also these size tire is less$$$. 3 more weeks till i get back home from training so i need to get these bad boys order. thanks
1 - 9 of 9 Posts
