1 - 7 of 7 Posts
my truck is LONG overdue for a good maintenance service, anyhow does anyone know what weight i should use in my front and rear diffs and tcase? i plan to use amsoil and need to find out what i need to price some stuff out, i plan to do this around may. im pretty sure my rear end is a c200 so its an open diff. thanks guys!
Royal Purple was around 120$ when I did mine I think it's about 3.5 or 4 qrts per front and rear. $12+ qrt. I think the weight was 75W90. Royal Purple calls it MaxGear.
amsoil isn't cheap, but it doesn't need to be changed again for a long time.
i think it'd make sense to use 75/90 if you run in any cold weather at all
if you're a manual make sure gl4, not gl5, goes in the gearbox
nope not a manual, 75/90 then, yeah it gets cold as hell here in the winter but then again can get hot as hell in the summer too. do i put 75/90 in the tcase too?
1 - 7 of 7 Posts
