Hey all,
I have a 1999 Nissan Frontier, 3.3 v6, 5 speed manual trans. I was driving home the other day and my truck started acting weird. It would be in gear, no grinding or anything but it wouldn't go. Thankfully, I got it home. My clutch was very sloppy. I installed new clutch master and slave cylinder hoping that would fix my problem. It did not. I bleed system thoroughly. Clutch now has good pressure again. I put the truck in gear, no grinding or trouble, let the clutch out and it will barely move. Even if I hit the gas, it barely wants to move. The driveshaft is spinning. Just asking for guidance on this. Could it be that my clutch went out or possible rear end problems? Thanks
