well, i would check fuses to start with. sounds like starter motor is not working or getting power.lights come on and everythiing works, it jus wont turn over.
the distributor rotor? ya, if it was over worn or something but idt it should move by hand if that is what you trying to do. you could try it its only a few bucks. it directs the charge to the intended plug for firing order. i would say, since its cheap anyways, just do a FULL tuneup and see if it works. probably needs it anyways.thanks for the info. i checked the distributor and it seems like the piece on the inside is not moving. ( have no idea whats it called) could that be whats causing it not to start not producing spark, if so not that much to replace.
