I have a 2002 Frontier extended cab and went "off-roading" last weekend. It was basically a long, flat dirt road that was wet as can be, and I decided to get loose. I flicked the rear left and right over and over while roosting the tires the whole time. Kept it under 4,500RPM the whole time.
After about 10 min of this, the check engine light went off and I lost power. Everything worked, except I put my foot down and the engine didnt go. I turned the truck off and back on, and it has worked well since then.
I ran the code, and its P0103 (High voltage to the mass airflow sensor), but I found this on the driver footwell the next day and was wondering if its related.
I would like to solve this myself instead of getting shafted by some shop. Thanks in advance for any help!
