I have a 2013 sv with 37000 miles I installed a rough country leveling kit a couple weeks ago and reclty I have a slight rattle clunk kinda feels like something is hitting the floor by the wheel wells. It's not a hard or loud clunk kinda soft but annoying. Any idea what it could be seems both sides have it
· Super Moderator
Check and tighten every connection.
Is the Rough Country a spacer lift?
Before I went with Bilstein adjustable's I had Calmini 2.5 inch spacers and it caused cluck through the steering shaft area, any chance this could be the noise you're dealing with?
Sounds like coil bucket contact. With that kit it should be expected in some situations. You can add bump stops to the under side of the UCA to soften the noise or buy aftermarket UCAs to get rid of it.
Everything seems tight it is a spacer lift and I installed the bump stops I've had the coil bucket contact but only on serious bumps and the bigger speed bumps. Do they sell the blisters adjustible in a kit by any chance?
They sure do. Just buy the shocks and reuse your factory springs.
I've got these on the 3rd ring with a half inch spacer on top... much better ride than the Calmini 2.5 spacers I had.
Front's only
Bilstein 24-187053 Front Height Adjustable Shocks
Front & rear
Bilstein 5100 Front Height Adjustable & Rear 5100s
