I need the 2 rails on the floor of the bed gone, to haul 2 dirt bikes. I bought a T-40 socket, removed all the bolts, but CANT GET THE RAILS UP? Does anyone know how to remove them?
get a bigger prybar.Bump.
Hauling dirtbikes across Texas tommorrow. Still cant get the bottom 2 rails out.
I wasn't able to remove the rails, but no big deal. I was able to pry up the end of one rail, but found no rust/grime/grit/or tape. Also, the bed is really clean and looks like it was never used. The rails are so stuck, the pry-bar made an indention in the bed before the rail would budge.Maybe there is dried crud/dirt keeping them stuck. I removed a top rail on my Titan and the bolts were the only thing holding the rail in place. Only other possibility is there is double faced tape under it.
