From what I can read most lift kits won't work on with the factory NISMO package with Blistin shocks. Basically I want to level off and lift my truck as high as I can with out extending brack lines, or any major suspension mods.
Trying not to mess up the warranty. I ideas on what kit will work the best?
I don't know if it will work on the nismo, but I installed the readylift sst 2.5 front 1.5 rear. Can't see why it wouldn't work unless there is something majorly different on my le.
I have the pro-4x (nismo) with the readilift. More expensive than others but it's complete.
I would go spacer lift and 1.5" blocks. You wont have to change any shocks. Thats what I did on my pro-4x (same set up). $60 spacers, $50 blocks, $50 U bolts. Then your alignment will cost some more buy the time you get the right bolts to adjust it.
