1 - 9 of 9 Posts
Hey guys I noticed I had a small coolant leak but I'm not sure what part this is. I was hoping you guys might be able to point me in the right direction.
Forgot to add it's an 06 Frontier V6
I hope I attached it correctly
I'll go look for my receipt, I replaced it on my Pathfinder and came with a couple of hundred dollar price tag as the leaking part is plastic that aged and got brittle. I bumped into it with my forearm while changing the camshaft positioning sensor. It goes across the firewall to the driver side too.
My Pathfinder had rear heat and air conditioning so the part was a little more involved as it also had a solenoid to open the rear heater core. In even had to drop the fender liner to get to the rear plumbing, what a pain.
The description says heater assembly on mine. Call a dealer and tell them it starts at the heater cover and goes across the firewall, they will know what you're referring to.
Try this, I found description and part number by using google
2010 Nissan Frontier Outlet Heater Hose Nissan 92410-EA200
You don't have your trucks year in your profile.
All fixed now? Happy to help you.
1 - 9 of 9 Posts
