this is actually a hardbody ?? i found what i thought was a small leak coming from under my 4 cylinder hardbody , its a 96 w/only 58k 5 speed , i thought it was the rear seal upon inspecting it , its not a rear seal ... ill try to explain what it is i can see it looks like some type of rubber boot from the shifter (looking under the vehicle) to the top of the transmission attached with a black zip tie from the factory well there is a rip in the boot , would the oil dripping out be brake fluid from the slave cylinder or just hot grease melting?? , its real clear and fells like brake fluid , and it does not leak bad just enough to drive me nuts,thanks Raceline.
