I have a problem I hope someone can help me with. I took my 2008 Nissan Frontier to Auto zone for a check engine lite told me my canister purge valve is bad took my truck home took the valve off put a OHM meter across the terminals and it read good 240 ohms no open when I checked the wire going to the solenoid there is no voltage with the key on and the truck started is it a fuse bad and if it is where is it engine comp glove box and what name would it have or is it getting its power somewhere else called a Nissan dealer and thy won't say HELP !!!!
