1 - 8 of 8 Posts
I’m posting here for a bit more exposure. Here is a video of a rattle I keep hearing in my son’s truck. It sounds almost like it is coming from the front left of the engine if you are facing the truck. I do not hear it on startup. Could this be a timing chain issue? I put a mechanic’s stethoscope where the timing chain is and out sounds normal.
Check the idler bearings. If no luck, start pulling belts and start her up. Pull power steering and ac belts first since runnin without those won't kill your battery.
Discussion Starter #8
Got that right! I took off the right front tire to get better access to it and it’s definitely the alternator. Rattles like a paint can.
1 - 8 of 8 Posts
