Vehicle: 2007 4x4 Nismo, 51k miles, never towed anything or been loaded with more than 4-500 lbs of stuff.
Symptoms: Clutch began to slip while on a trip--seemed that it wasn't fully engaging when the clutch pedal was released. Had just replaced the clutch slave cylinder, properly bled etc.
What I did: while on the trip, suspecting the new slave cylinder was defective, I had it replaced with another new one. Same symptoms. Mechanic then cut about 3/8" off the slave cylinder pushrod--that allowed the clutch to fully engage, but it was still slipping--less than before but still slipping. After about 200 miles on the way home, the clutch failed altogether.
Had it towed to the nearest dealer (only a mile away)--Carolina Nissan, incidentally--they were very good. When they pulled the clutch, the lining was completely worn off the disk; both pressure plate and flywheel were scored. They replaced the assembly, and reinstalled the second slave cylinder with a full-length pushrod, and all was well.
Question: What happened? Are Frontiers notorious for clutch failure? If so, which part? Anyone know of a hidden/goodwill warranty on clutches? The problem couldn't have been either of the new slave cylinders. It's not me--I've been driving manual shift cars exclusively since 1963 and have yet to burn out a clutch--150,000 plus miles is about average for clutches in my vehicles. Neither the mechanic who installed the original slave cylinder, the mechanic who installed the second one, nor the techs at the dealership who did the clutch could explain it...Any ideas?
TIA
mike
TIA
mike
