1 - 7 of 7 Posts
I think your first place to look is a junk yard.
Are you 1st or 2nd gen?
If you are 1st gen, you may want to look into a Maxima e-fan swap.
If you are 2nd gen, then you may want to look into a dual e-fan swap.
These options will eliminate your fan blade braking issue.
Discussion Starter #3
yeah i thought about the e-fan what year is it so when i hit up the junk yard i know what to look for
and its a 1st gen
check your motor mounts.
There is a write-up on the maxima e-fan swap. It is probably in the "1st gen" section of the forum.
Good Luck on your search.
1 - 7 of 7 Posts
