So all of my ABS lights are on, and I have a few codes popping up. When I checked the ABS codes I found:
C1143 - Wheel speed sensor LR Tone ring tooth missing fault
C1163 - Park Brake switch #2 Applied circuit short to ground
C1111 - ABS Power relay coil open circuit
I did not get the descriptions with the codes, so I am not 100% sure if they are necessarily correct. I used Cypher to retrieve the codes, and then looked up the code descriptions online. I don't know if they all came on at once, or at different times. My truck HAD been sitting for about 5 months til I changed the motor. At which time the battery was unplugged and had been moved around the shop manually quite a few times. I had read some where that if the battery is unplugged and the steering wheel is turned, it can set off wheel angle sensors????? So I have been driving my truck the last couple days under the assumption that, that was my problem. Turns out it's not I guess! Unless these codes are related to the steering angle sensor dealy somehow? IDK?
Any help or any information on these codes? Or what my problem might be? Or if these are all related to each other? Anything?
All help appreciated
Thanks in advance.
Thanks in advance.
