I did a search and couldnt come up with anything. I was wondering what I would need to do to move the constant hot from the lower outlet on the dash to the outlet at the armrest?
Thanks.
Thanks.
First, pull the 20 AMP fuse from the fuse block under the hood before you remove the hot wire the hot wire from the back of that outlet and add a length of a wire and run it from there under the console to the armrest outlet and splice it in. Re-insert the fuse after you have connected everything and check to see that you were successful.I did a search and couldnt come up with anything. I was wondering what I would need to do to move the constant hot from the lower outlet on the dash to the outlet at the armrest?
Thanks.
