1 - 4 of 4 Posts
So i want to mount my light bar in the lower front grill area.. but i have a question..should i drill a hole through the metal bumper underneath the plastic ..or mount it to the plastic.
If i do the metal..how can i mount it? I see that the metal it thick to where the bolt wont reach the other end for me to secure my nut
Sent from my SM-G930F using Tapatalk
There are two brackets that hold the bumper to the frame. On the right and left. The right side has a hole already, the other side you can drill o e hole. I used scrap aluminum and made some cheap brackets. Took all of an hour from start to finish. Maybe a little longer with finishing up the wiring .
Sent from my XT1585 using Tapatalk
1 - 4 of 4 Posts
