Hey guys maybe you can help me with a little problem I am having. I am currently putting my '01 3.3L frontier back together after replacing both head gaskets and once I started installing the timing belt I noticed that their is not a timing mark on the oil pump housing like the manual says their is. Has anyone one else ran into this problem and if so how did you overcome it. I have the OEM replacement belt that has the marks on it. If I line up the two cam gears and the crank gear to the belt and turn the crank 2 full revs one cam is 1/2 tooth off and the crank is who knows where because I have no mark to line it up with. Any help would be great.
