Firstly I apologize for the long post, however I am going to try and make it as clear as possible as to what I have done so far and what is going on with my truck.
The truck is a 2002 XE Crew cab 4x4 with a 3.3l V6 non supercharged engine. The parts I have replaced so far include the following:
Air Filter
Spark plugs
Spark plug wires
Distributor cap
Rotor button
Fuel filter
Fuel injector cleaner in the tank
Now for the problem, I have a recurring misfire on cylinder #6, that will set the engine check light. I have a diagnostic scan tool so I am able to clear the code, however it takes less than 1 day to re-occur. After a night of standing usually the first start of the morning the truck idles really rough, at this point no engine check light is flashing or set. The engine continues to warm up and will set the light solid after about 1 minute of idle. If I clear the code with a scan tool I can drive the truck the whole day with stops and starts and it will not set the light. I do however feel the engine running rough when I stop at a traffic light, but it will not set the engine check light nor do I get the light flashing as others report in the forum.
I am at a total loss at this stage apart from tearing the intake plenum apart to check for air leaks or maybe a faulty injector. However I have unplugged other injectors and they do not set a misfire code. Any help at this stage would seriously be appreciated from fellow owners. I am very experienced at rebuilding motors and working on cars and trucks, this one has me fooled.
Air Filter
Spark plugs
Spark plug wires
Distributor cap
Rotor button
Fuel filter
