2001 Frontier 3.3L KC 4X4 MT
Have a 2001 3.3L v6. Had a trouble code P0301, thought I narrowed it down to a bad fuel injector in cylinder 1. Checked the ohms resistance in cylinder 1; 36 ohms. From what I've read the range should be 10-14 ohms. Cylinder 3 & 5 were 12.2 ohms. Replaced fuel injector in cylinder 1 with a new one, started it up and it seems to run rougher then before I changed injector. Pulled trouble code PO306. Tested ohm resistance on cylinders 1,3 & 5 just after a test drive and got 14.2 for all 3.
So I went from a misfire in cylinder 1 to a misfire in cylinder 6. Due to the location of the fuel injector for cylinder 6 I have not tested it yet, would need to remove the plenum intake? Any tips or suggestions on what I should try next?
Yes, pulling the plenum is a bit of a pain.. On the plenum near where it mounts to the lower manifold, there will be a couple of EGI ground points. Look for a bunch of black wires go to two, 10MM head bolts. I would remove the bolts and use a Scotch pad or light sandpaper to clean up the wire eyelets and contact area on the manifold to make sure you are getting good grounds. I would also look at the distributor: check to make sure the rotor bolt hasn't loosened up or fallen out, check for play in the rotor shaft, look for signs of rust and/or oil (which would indicate a bad shaft bearing and/or seal). Make sure your secondary ignition system is in good shape (plugs, wires, cap/rotor).
Discussion Starter #3
I'll give that a try and thank you for the advice, hope it works.
Discussion Starter #4
So quick update. I was able to check ohm resistance to all injectors all reading 12.2 ohms. Cleaned grounds and inspected cap/rotor and wires, confirmed spark to all wires as smj999smj suspected. Drove truck for 20 mins and no code came up when I scanned it. Truck does seem to be running rough and is much more difficult to start after I replaced the injector. Before the injector replacement it started strong on first crank, know it takes 5 -6 cranks before it starts.
Any advice as to why the rough running and hard starting after replacing an bad fuel injector?
I've seen people damage the seal on the injector during installation, which would create a vacuum leak. Did you lubricate the seals before you installed it into the rail? I usually coat the fuel injector "O" rings with Vaseline. It's also possible to get a bad part.
