Negative. Its a QR25DE, which is common to 02+ Altima, 08+ Rogue, 02-12 Sentra (incl SE-R & SE-R Spec V).I'm sure the 2nd gen engine is just a retooled version of the KA24D type of engine right?
Can you explain the repairs in a little more detail. Was front "hub" a wheel bearing? and you have had to replace your evap canisters 18 times? and 18 valve replacements too? Its unclear what you had done. Was the truck new when you purchased it? or used? Thanks for clearing this up.2010 xe bought in October 2010 152.000 miles,1 front hub and 18 evap canisters and all the vales every time
10K on a 10 year old truck. Dang do you have a lot of cars or do not drive much. Babying that 2003.Da da da Daaaaaaaaaaaaaa. I finally turned over 10,000 miles on my 03. Sadly, it was on the way to work yesterday............
I will be glad to give it its next oil change at 12k so I can tighten the a/c belt a bit, she is chirping once in a while again.
I have over 300000 miles on my 09 frontier only changed plugs belt and oilI only have a little over 40,000 miles on my 2009 and was wondering how long the motors last. How many miles do you have? Any trouble?
