1 - 9 of 9 Posts
Hi folks.
I have a 2017 Pro 4X. It is not lifted and I am on stock wheels and tires. I get a pretty good metal on metal sound out of the front left when I hit a good forest road pothole at speed. Anyone know whats going on here? The bumps stops have obviously been in good use with how clean they are. I poked around and see no obvious contact point and no loose bolts that I can find. However I do see several small chunks of aluminum removed around the inside lip of the front driver side wheel. The passenger wheel has a few paint scrapes in this area as well but no heavy material removal.
Thanks,
John
Drivers wheel inside lip:
And a few fun pics to keep it interesting. I am loving the truck so fan with the exception of a few issues like this.
Clunk? Thunk? Scrape? Is it happening when you bottom out or top out the suspension? My initial thought is Coil bucket contact when the wheel droops fast and far enough.
I would call it a clunk. Things happen fast, so I'm not sure if it is bottom out or top out. I checked for contact in the spring bucket area and did not see any. Granted it has only happened maybe 5 times since I have owned the truck. Truck only has 3k miles on it.
All you will see on the coil bucket is a shiny spot were the lip of the control arm is contacting. You would probably have to be hitting it frequently to have it leave a mark (as I did with the coil spacer lift). I would assume without a coil spacer you really shouldn't be getting the contact, but, going fast enough, who knows.
I will check the suspension at full droop and see how close those parts are.
That road is a spur off of NF-6710. Nothing technical, just beautiful land up there. And not a single person out there even on a holiday weekend.
Well I finally got around to jacking up the front left corner and I do not see any contact of the upper a-arm and the spring bucket. There is a good 1/2" of clearance. What I did notice is that the front skid plate is really close to both the frame and the sway bar on either side. I can get those to contact the skid by just whacking the skid with my fist lightly. After playing with the skid, I may have made slightly more clearance as I am now not hearing the sound when driving over curbs. I will find out next time I am in the mountains.
Oh, I also removed the Utilitrac covers, that was not the source of the noise.
1 - 9 of 9 Posts
