1 - 7 of 7 Posts
My automatic 2005 CC 4x4 Nismo, for a while felt like it would search for a gear and then would buck pretty hard when it shifted. Last week when driving I went to accelerate while at cruising speed and it felt like I went in to neutral it would rev but had nothing and coasted to a stop. It wouldn't move in any gear but would rev like in neutral. If its off for a while it will drive but then after about 100yds or so it does the same thing. Am I just going to have to accept that I'm going to have to get a new transmission or is there something less severe going on. I am not much of a mechanic either so no matter what it is I will be taking it in somewhere. Thanks for any and all help.
2005 with V6 engine and automatic? If so I hope you've had the radiator replaced or the transmission fluid part bypassed !!! Coolant can get into transmission, and ATF into the coolant otherwise, causing BIG damage.
Sounds like the clutches may be wiped. The SMOD symptoms I've seen in the past are typically a little different than what you describe. Have you maintained the fluid? IE: What change intervals? And typical usage? Fluid used?
May be a dumb question, but have you checked the fluid level? Low fluid could cause some of the issues you are seeing. How does it look also?
See what colors mean here: AGCO Automotive Repair Service - Baton Rouge, LA - Detailed Auto Topics - The Color of Automatic Transmission Fluid
Thank you all for the help, I have a feeling I'm about to drop a lot of $$$$ in my poor truck. I didn't know about the SMOD. I had this account originally for info on mods from when I first got my truck. Should have taken advantage of the mountain of knowledge in front of me and dug around more. I now know where to start at least. After checking my fluids and such, if it does end up being the SMOD issue and other than needing a new transmission and radiator are there any other tips? Thank you all again.
SMH, I wish there was a way to auto send that sticky thread to you guys with 2005-2010 with V-6 auto's. it's so sad how many of you fail to notice that issue or sticky thread until it's too late. Sorry for your troubles.
Perhaps there could be an instant-ish/discretionary reply (by a moderator) to new members with a few of the important things IE '05-'10 SMOD, the acronym thread...just to name two.
1 - 7 of 7 Posts
