Lower Dash Cubby Part Number
1 reading
3K views 9 replies 6 participants last post by  808UpFront
#1 ·
Hi All,
I have a 2013 S crew cab 2WD. I have noticed on some of the older 2WD models with the same dash as mine there is a cubby in the area where the 4WD switch resides. I am talking about the real base ones that have the large cubby encompassing the entire area like in the truck in the ebay ad below:
Nissan Frontier SE | eBay
There is another design out there with a smaller cubby and an area for the 4WD switch which is not wham Im looking for.
Does anyone have the part number for that cubby? I want to use it for a project I'm doing (I'll relocate the traction control switch).
I have been through the Courtesy diagrams but can't nail it down. Thanks.
#2 ·
#3 ·
That is the only piece that makes sense. The only other place I could see that is if there was a model offered with a single DIN stereo and that piece went below it. If the opening is just a DIN sized opening I probably have something that will fit though. I may go ahead and order it and see.
#6 ·
OK, I really hope this part will work with the S, having the circle for the 4 wheel drive selector, 1 switch and 3 blanks just bugs the hell out of me each time I look down there. I can use this plate on my X and have a place for the switches I will likely add in the future, but the Frontier will never have anything there.
That being said, is the wiring for the traction control button long enough to put beside the non existent mirror adjustment switch or do you need to extend the wires?
#10 ·
