Maybe you have a bad sensor. I don't know of any way to disabl it other than covering it with black tape.Whats the easiest way to disable the LTP light? tires have never been low, light came on, tires have 60 pounds of air. im tired of looking at it
wee
lol, thought maybe someone knew a wire to clipMaybe you have a bad sensor. I don't know of any way to disabl it other than covering it with black tape.
Not that I have heard of. It has been discussed many times on this forum and so far there is no easy way to disable the light that I know of.lol, thought maybe someone knew a wire to clip
wee
hmmm, ill try thatunless you're driving a big duelly diesel and towing a billion lbs, try lowering your tire pressure to something within the PSI range the TPMS is meant to read.
That's an interesting thought. Do they also trip on overpressure? I never really gave that any thought... Chip.unless you're driving a big duelly diesel and towing a billion lbs, try lowering your tire pressure to something within the PSI range the TPMS is meant to read.
That seems odd since the spare doesn't have a sensor in it.My TPMS light was going on randomly. Tires are fine. I checked the spare and there was only 19 lbs. in it. Topped off the spare and the light hasn't gone off since.
Why wouldn't it? I have a full size oem-NISMO wheeled spare.That seems odd since the spare doesn't have a sensor in it.
Does it have a black rubber valve stem? I also have a full size spare with an OEM alloy wheel. It does not have a sensor. What year is your truck?Why wouldn't it? I have a full size oem-NISMO wheeled spare.
Weird indeed. I had my spare on because I was getting a flat repaired. The first time the light came on as soon a I left the tire shop. The second time I dropped the same tire off for another flat repair my light did not come on at all. Never could figure that one out. I sometimes get a random flashing TPMS light during the winter months. It always seems to happen about 23 miles from home on the way to work in the morning.It's a 2005. Yeah it does have a black rubber stem but it only had 19 lbs. in it and now that I filled it up it the light does come on anymore. Hmmm, weird.
For me it's about 40-50 miles to work, I drive 58 miles one way. The other day it was during the afternoon about 15 miles into the drive home. However, not since. Maybe I should wait longer, it may come on again. I have nitrogen form costco in the tires, except the spare.It always seems to happen about 23 miles from home on the way to work in the morning.
