1 - 3 of 3 Posts
I'm looking at buying a used Frontier. I found a truck at a local used car dealer and was wonder if I could get some advice.
What kind of gas mileage ("ball park") should this truck get?
Does this sound like a good price?
Details below:
"02 NISSAN FRONTIER XE KING CAB**4X4**V6 5 SPEED**DESERT RUN MODEL**$7650"
Thanks for the help.
Well its not going to be a 4x4 if its the desert runner model i believe. Cause that is what i have its just a pre-runner. How many miles are on it?
2002 and earlier have cracked manifold problems. 2003 and newer were fixed.
If it's over 105,000 miles make sure the timing belt has been replaced. The v6 has belt and not a chain.
Get under it and look at everything. If anything is bent then it's been 4x4 off road and probably should steer clear.
However, the Frontier is a solid truck and should last you for awhile.
1 - 3 of 3 Posts
