1 - 20 of 23 Posts
Just wanted to ask for references or sites i might be able to order affordable long travel kits for my 2015 kingcab
If anyone has installed one before may i also get price cost..and experiences.
Thankyou
Sent from my SM-G930F using Tapatalk
Gone but not forgotten Member
Most affordable kits are mid- travel.To go long travel will take a lot of fabrication."PRG Products" makes a popular mid travel T/S kit. "BTF" and "Dirt King" make kits considered long travel.
Would i need to fab or.cut anything off my truck? Or is it a bolt-on type kit? You have a website i can look through?
New to fixing up my truck and im addicted haha
Not with the T/S PRG kit. I ran the T/S PRG kit for awhile but I built hoops for my truck. I also strapped and ran hydro bumps.
You will still need to do the rear and you will still be limited to mid-travel.
I now run a BTF fabrication custom kit(1.5 uni-balls).
Google PRG Products,BTF Fabrication,Dirt King.
What do you want to do with your truck?
What do you consider affordable?
saw this on google..idk whos truck this is but i want mine to have thise stance n build..going for the looks
That makes a huge difference in price.
You can just run lift spacers,wheel spacers , might need shocks and alignment bolts for the front.
Aal springs and or blocks,shackles for the rear.This will lift the truck but will do little or nothing to improve travel.
Okay nice im just going for look..not really on the performance side because i only own a desert runner and its my daily driver..but on the same boat i wanna make it look sick.
I have already installed a 3" front 2"rear leveling kit..so next wheel spacer..what size u think? 2inch?
That would give you close to a T/S width with" spacers.Motorsport Tech is a reputable company for spacers(Bora) and they will make them even wider.
Not sure about clearance issues.
Are you ok with the height you now have?
Yes i like the height i dont wanna go any higher i just want that beefed up look...ill look into wheel spacers
You might want to check out the updated sticky in the suspension forum.
I might not be the best person to offer "looks" suggestions.My build is more performance oriented.
You might want to look at my "2007 build" thread.
No,don't know anything about them.They might be ok.
I only buy Motortech Bora spacers which are quite a bit more expensive($150).Those are the only ones I can personally recommend.
They are only 1.5" spacers also.
You might want to consider a Titan swap.
I don't know the availability of parts in Guam but if you can buy Titan upper control arms ,it would be a better way to go.
It would increase your stance to 5" versus 3" with those spacers.
Look up Glamisdiude's
thread on a economical Titan swap.
Discussion Starter · #16 ·
Ok man thanks alot i see you know your stuff..
Discussion Starter · #17 ·
I cant find the thread would u happen to have the link?
I can't get to my computer right now. I don't know how to send the link on my phone.
Go to the suspension forum. There is a sticky titled "How to , compiling Titan swap components".glamisdude took a lot of time putting this together.
Sorry,you are going to need Titan lca also.
Reactions: rytious671
1 - 20 of 23 Posts
