1 - 3 of 3 Posts
Long time forum reader with a 2015 Pro4x.
I diagnosed a weird cab water leak that I haven't seen anyone ID before, so I figured it was time to register and make a post about it.
wow, you didn't tell us where you suspect the leak coming from or anything, could you be more vague?
PS Welcome :)
::smile:: There is a pretty hefty write-up pending Mod approval over in the DIY section. I also summarized all of the other leak info I found while troubleshooting.
TL : DR - The rear sunroof vents feed into a plastic fitting. There is a neoprene gasket that can be misaligned from the factory that lets water draining out of the tube make a u-turn right back into the cabin. Also lets water draining down the back of the cab in.
1 - 3 of 3 Posts
