Hello!
I’m hoping to get a bit of help with an electrical project.
I’m planning to install some driving lights to augment my headlights on rural roads. I’d like to set this up so that when the Fog Light switch is ON, the Driving Lights come ON with the High Beams. In other words, the Fog Light switch becomes the “Additional Light” switch where when it’s ON and the Low Beams are ON the Fog Lights are illuminated, and when it’s on and the High Beams are ON the Driving Lights are illuminated.
What I assumed would be a simple task has, upon inspecting the wiring diagram, started looking much more complicated. Damned computers are a pain in the butt.
If I understand correctly, the BCM polls the Combination Switch at a 20ms interval, inspecting the status of the controls on that combination switch and sending state messages over the CAN bus to the IPDM E/R, which then controls the various relays to activate things.
What I’m afraid this means is that there’s no traditional (ie: non-digital) way to detect that the Fog Light switch is ON when the High Beam switch is ON, since the only system that detects the position of the Fog Light switch is digital.
What I had wanted to do was to wire the coil circuit of a power relay for the Driving Lights by pulling a shunt from the High Beam feed wire and routing it through a control relay toggled by the state of the Fog Lamp switch. Thus, when the High Beams are on, the circuit to the coil of the Driving Lights would be energized, but that circuit would only be closed if the Fog Light switch is ON. But because I’m not seeing a non-digital way of knowing if the Fog Light switch is ON when the High Beams are ON (because the computer turns the Fog Lights OFF when the High Beams are ON), I can’t make this work.
Anyone know an easy way to get a constant 12v (or ground) feed from the electrical system at all times that the lighting system is active and the Fog Lights are ON?
Thanks,
-Ben
Thanks,
-Ben
