1 - 3 of 3 Posts
I already have a 2 inch spacer lift and thought I could fit some 285/75 R16 BFG. I put them on and they rub pretty bad. I trimmed the front lip on the bottom of the front bumper but they are still hitting fender liners pretty bad. My question is should I go up to a 3 inch spacer or would wheel spacers help? Also, if I do go to a 3 inch spacer is there anything else I have to worry about as far as shocks or drive train? Thanks.
Wheel spacers will make it worse.
Are you running stock rims or aftermarket?
Sent from my SM-G900V using Tapatalk
Have you read through the sticky under suspension? suspension lifts
did you do the "melt mod" ?
1 - 3 of 3 Posts
