New to the world of Nissan I have an 01 king cab SE what what be a good choice for a lift kit or what should I use I did some reading on here and found the brands I was looking at were no good and I do alot of off roading. Second what is the safe height you can lift with just torqing the torsion bars. And where to find a bruhs gaurd?
Thank you
you can get an 1.5 lift from just cranking the bars
3inchs with Calmini or AC upper arms with AC being the better choice
rear AC ad a leaf is the best bet
also if you wheel brush guards are a very bad idea they will damage your truck. I cant count the number of brush guards I've taken off in the parking lot before a run.
4x4parts.com is a good source for parts
Cranking up your torsion bars 1"-1.5" is a good idea for ground clearance. It's also free if you do sit yourself, just check to see if you need an alignment. If you have a few bucks to spend, look into Calmini. For about a grand you get a 3" suspension lift, which you still need to install. If your short on cash, crank the torsion bar, and maybe do a 2"-3" body lift. You won't get any ground clearance from a body lift, but you will from the bigger tires it will allow you to put on.
Thank you very much I am going to do the torsion crank for now and I am going to save up for the Calmini lift kit and winch front bumper along with there side rock gaurds so I can take off the factory nerf bars I keep scraping them on rocks.
