1 - 2 of 2 Posts
Recently I installed a leveling kit from supreme suspension that raised the front and rear a couple inches. I installed it myself and to do so i had to engage the suspension when reconnecting the control arm. So I placed the jack somewhere under the lower control arm until the suspension compressed and I could connect the pieces. when I started driving their is a metal on metal scraping noise from the brake. When I had the alignment done they said the disc was rubbing and they would move it and the scraping decreased but still scrapes when I turn to the left. Its coming from the passenger side. Can I do this myself or should I bring it back. SImple fix?
P.S. if you are getting a kit get the camber bolts yourself for the alignment, they tried to charge me 160 for four bolts when they are like 30 bucks online. Maybe that also something I could have done myself.
Sounds like it's the dust shield hitting the rotor. Jack it up and spin the wheel. If you here scraping bend the shield away from the rotor.
Reactions: Skinny06
1 - 2 of 2 Posts
