1 - 17 of 17 Posts
don't really see much about this setup for our trucks so since I just purchased one I figured id share it here. I added a Leitner ACS (Active Cargo System). I really needed racks for work, but also wanted it to be more than just a rack. the Leitner Design is above par, amazing quality and the thought that went into this system, allowing it to be so easily added to for your needs is just amazing. install was a breeze, I do not have the factory utility tracks. I added two gear pods which have a very nice seal and they are lockable. 10 gallons of storage, yippee!!
the rear cross bar has nice rubber nobs for more less a quick release type setup allowing you to easily slide the rear bar forward for clearance if needed
the front cross bar with the more fixed mount, but still easily adjusted and the slide system on the rails allows you to put these anywhere
Any issue with the blind spots created by those boxes?
The nice thing about the gear pods where I have them is that they don't make a blind spot, they basically hide behind the head rests in the back seat of my crew cab. They stick out a little more but I really don't notice them so I don't feel like they added or created a blind spot. Now if they are moved back or another set of accessory pods are added they would creat a bigger blind spot for sure.
If you don't have the utility tracks they send special "C" type clamps that slide into the base of the rack which also sits on the top of your bed. An adjustable screw (3 on each side) then tightens down or into the under side of your bed rail. Very easy to install. I will grab some pics and post them up.
2016 Frontier SV 4x4 Crew Cab
wow that is a super cool system. i have a canopy purely for rain protection when im hauling stuff but i would much prefer something like this that i can just take down whenever i don't need it.
BUMMER. says DISCONTINUED ...
NISSAN
Discussion Starter · #14 ·
NISSAN
Yeah, but when I spoke to them they told me the chevy Colorado is the same size and fits the Nissan so your still good to go if you want one.
I just got the forged rack. The clamps won’t fit towards the tailgate due to it tapering to 2 1/4”.
1 - 17 of 17 Posts
