1 - 19 of 19 Posts
Hey everyone, I am really wanting to add a led light bar to my 2003 extended cab SC, after seeing the outstanding difference that all of my friends light bars have made for there night time riding. I have searched everyone and can't seem to find anything for mounting brackets to put one above my windshield. Any ideas or suggestions/pictures?
Is there a shop local to you that has brackets on hand? You're probably going to have to use a set made for a different vehicle. Most you must drill through the roof to mount. I'd try holding a few up to see what works best. Maybe something for an older generation Tacoma.
This light bar doesn't require any additional brackets/roof mounting if you have the roof rack. It mounts in the factory holes for the airdam. This bar is an all flood light bar. On that website they have others that are combo spot/flood but they will require brackets/mounting to the roof. It's very bright, maybe not the brightest bar you can get but it will make a difference.
39" Compact Off Road LED Light Bar - 108W | Off Road Light Bars | LED Work Light & Off Road LED Light Bars | Super Bright LEDs | Super Bright LEDs
Just flip the included brackets backwards, buy some slightly longer bolts and there ya go.
I have one in the grill as well. 24"
Site Sponsor
Our 40" light bar comes with the universal mounts that will work well on the Frontier. We assemble our light bars here in St. Louis and they use CREE LEDs.
Feel free to give us a call if you would like more information: (314) 205-3033
Nick C.
Nice truck, the OP has an a king cab (extended) so no roof rack for him (most likely.)
Aww damn good call. I missed that part. I made that big post for nothing! At least aR liked it. :)
Nick C.
Ohhh that one looks nice! How many lumens? Is it a combo spot/flood or just flood light? EDIT: answered my own questions on your website. 24000 lumens and you can choose spot, flood, or combo. NICE!
Discussion Starter #8
Thanks for all the info! But yes I do not have a roof rack, so what I am thinking is either having a stock roof rack shortened to fit my truck and then adding a light bar to that, or going with something that comes with universal mounts like posted above. I think I will check into the universal mount light bar posted above before anything else. Sweet set up by the way MetalAlien!
Where did you run the wire into the cabin? Did you end up drilling a hole for that?
Yes but you drill under the mounting point for the roof rack which is already weather proofed. You run the wires inside the roof rack. You don't have to worry about any additional weather proofing or anything like that.
Or you could buy Rough Country 70507 - 50-inch Curved LED Light Bar Upper Windshield Mounting Bracket and with very little bending it fit me 2001 SE Crew cab perfect. I only used my body weight(145lbs) to make the slight adjustments.
What length light bar did you use with those mounts?
how is the one in the grill mounted?
Sorry to resurrect this thread, but I have the same question..
How IS the one in the grill opening mounted?
I made a bracket to mount it to the metal frame inside.
^ Oh Shyt, It's MetalAlien. I figured you had sold your Frontier and Moved On.
Hell no I didn't sell it. Where else am I going to dump all my money? Trying to get money together for an LS swap but good luck on that... everytime I get a little money something happens and I need to use it.
1 - 19 of 19 Posts
