1 - 4 of 4 Posts
My leafs are shot. Most likely original (144k now). My passenger side sits about 1 3/4" lower than the drivers. I wouldn't mind a slight upgrade, but want ride quality first and foremost. This thing is not an off roader. I read several posts on leaf spring recommendations, but most were on lifting, etc.
Will going with HD leafs be better than the standards?
2005-2016 HD Leaf Spring Nissan Frontier | General Spring
Also, anything else I should consider replacing in the rear while I'm at it?
Any thoughts welcomed.
Never seen that company before. But looks like a good stock replacement. I would not get the HD spring unless you carry a load regularly. You should replace the bushing. Seems like they come with new bushing. I would also replace the shocks "while you are at it".
It is also recommended that you replace the U bolts/nuts whenever you remove them. At $6 I would.
Please report back when you have finished this job.
Best part is that they are in my backyard and I can pick up local. Save $50 bones for other activities! I'll report back once I've pulled the trigger and then again on install.
1 - 4 of 4 Posts
