1 - 4 of 4 Posts
The S-trim base trucks have the exact same suspension as the higher trims, correct? So they can have 31" tires as well (what the more expensive trucks have from the factory)? S's come with 28's and sit a whole lot lower to the ground.
Get verification on that to be sure or you’ll have an expensive error. You’ll only sit 1-1/2 inches since it’s a three inch difference.
KC or CC in 'S' trim? KCs come w/ a 4-cyl while CCs get the V6...so suspensions & payloads are not the same, IIRC.
1 - 4 of 4 Posts
